Today I 3D printed the first version of this air vent hood to fit my L7 and L1. My idea is to mount this on my container and stick the hot end of the miner straight into the hood. This print I did with minimum weight because it is for sizing. I have a slight lip on the inside which will extend into the container and be able to fit the length of the fans before the slope starts and on the Inside will also make a box to join and cover the PSU fans as well. So the miner can fit in and out real easy. I will be testing the temps before fixing it onto my container and cutting holes
