I currently have my mining room divided into two sections. The hot side is exhausted with a powerful HVAC squirrel cage fan and sends the hot air outside. However my room can get up to 100 degrees F during the summer. My question is, is it worth adding another squirrel cage fan to help exhaust more heat? Or am I better off purchasing some hose adapters to put on the back of the miners and sending the heat right outside?
Thank you!
Just put in a exhaust and intake fan but 100 isn’t that bad. In summer my hot side can reach 120 plus but cold stays at outside temps
