Where can I get the fancy 6 pin braided cables
I’m having issues with 6 pin cables from random sources being a bit under spec. Where can I get the 16g braided cables? I seem to be able to find 8pin > 6+2 pin, but I’m not sure that will work on the breakout board to run the goldshells which is 6 pin both ends.
you may have to find something off the shelf and adapt it.
is this for a gpu rig or asic
Goldshell Boxes.
I was watching hobby miner talking to veteran miner about the cables veteran does, but couldn’t find a link.
Do you have a picture of the cable? Send it to the sales manager of ZEUS MINING and she will find the most suitable cable for you. Or are you looking for this cable:
https://www.parallelminer.com/product-category/power-accessories/cables/
Would this be your guilty pleasure?
Thanks
Doug
