IceRiver AE0, Goldshell AE-BOX, Goldshell AE-BOX Pro—Which One Is Your Best Partner In ALEO Mining?
Aleo is a Layer 1 privacy public chain project based on zero-knowledge proof technology, which aims to provide a completely private application environment and protect user privacy. Aleo’s core technology is zero-knowledge Proof (ZKP), which allows developers to execute smart contracts off-chain, ensuring the privacy and scalability of transactions.
In the field of ALEO mining, choosing a suitable mining machine is the key to obtaining ideal returns. IceRiver AE0, Goldshell AE-BOX, and Goldshell AE-BOX Pro are three mining machines that have attracted much attention. Next, we compare them in detail from multiple dimensions to provide a strong reference for your decision-making.
Computing power and power consumption:
IceRiver ALEO AE0:
- Computing power: 50Mh/s, power consumption is only 100W, and has a very high energy efficiency ratio (2J/Mh). This ratio of computing power and power consumption is ideal for any mining machine.
 - Advantages: AE0 provides the highest computing power on the market with extremely low power consumption. Compared with other miners, AE0 has almost no competitors in terms of power consumption, and its power expenditure is significantly lower than similar products. For areas with higher electricity prices, AE0 is obviously a more economical and affordable choice.
Goldshell AE-BOX:
- Computing power: 37Mh/s, power consumption 360W, energy efficiency ratio 9.73J/Mh. Although the computing power is not as good as that of AE0, it is still at a relatively high level and is suitable for users who are looking for higher computing power but do not require extremely low power consumption.
 - Advantages: AE-BOX has strong computing power and is especially suitable for miners with relatively sufficient power resources. Despite its higher power consumption, its lower initial purchase cost makes up for this.
Goldshell AE-BOX Pro:
- ****Computing power:****44Mh/s, power consumption 460W, energy efficiency ratio 10.45J/Mh. Compared with AE-BOX, AE-BOX Pro has higher computing power, but its power consumption also increases significantly.
 - Advantages: AE-BOX Pro is suitable for large mining farms and miners who require higher computing power. Although its power consumption is relatively high, the high computing power of this miner still makes it an attractive choice if power resources are sufficient. There is no change in the appearance of the machine. The power interface has changed from two 6-pin interfaces to three interfaces. The machine has wifi function, which is more convenient and convenient.
