Was just thinking the other day @Krisz said he uses the heat from his miners for his greenhouse. I am trying to use my water cooled L7 to heat an outdoor shower. Does anyone here re-use the heat in any other way? I’m sure there would be some home heaters here for sure! Would be cool to see some pics if you have any
Last year I set up S9’s in my greenhouse. I’ll probably put a s17 in there this year. I was also thinking of converting one of my s19’s into water cooled and connecting it to my solar water heater setup.
Did you see Linus heating his pool with GPUs a year ago? Can’t remember if worked or not but was a fine project.
I was actually talking to another kiwi who tried to heat his spa with GPUs but he called it a failed project I think he could only get it to 34 degrees from memory, he made YouTube videos on it. The power consumption of ASICS so so much higher though, my parents spa is 2.1kw I think and that turns on when it gets under 38 degrees I think. I asked them if I could heat it with my L7 and they said get lost
I’ll have to look up the pool video, i defs have heard people doing it, would be interesting to see the temps they can get the water to considering the large volume of water
