I’m setting up a shed to mine in. Here’s the stats.
8- S19J Pro 104th’s
2- L7’s
5- KD Boxes
3- Mini Doge boxes.
Ive finally got the power figured out almost on all of this mess, now I’m concerned with the heat.
I’ve got a 12 x 35 foot shed. I have a 9000 BTU Mini Split above the miners, and a 30" 1/2 hp exhaust fan at the other end of the shed pulling air out.
With only 7 of the 10 ASICS running, I’m pushing 103 Degrees on the intake side and 110 degrees on the exhaust side of the miners in the afternoons.
Question is… Is this too hot? If so, how do I reduce heat in this damn building. See photos below and please let me know what you think.
Well to start the small ac unit or any is useless waste of power I’d spread them apart I’d move closer to exhaust fan to get heat out and that looks bigger then a shed u have a car in there so figure u need to exhaust all the air in there in my figure we’ll under a min then replace with more air then you are exhausting and I live in Tuscon az in a desert might want to insulate
Do you know how many CFM your exhaust fan produces?
I suggest creating separate hot area for all miner exhaust so it’s not heating up the rest of the air. Build a floor to ceiling wall. Cut exhaust ports in it and slide the miner exhaust fans into the ports. Your big exhaust fan will pull the heat out if it’s sized correctly. The mini split will help cool the intake side better this way.
You could close in that spot to cut down on area u are trying to cool smaller better but not to small then u can exhaust the hot air out and new air in or put in vent for miner to vent out each miner but u definitely need get that temp down what are the asic temps
Not sure how many are mining in a desert but air flow movement is the most important part u need to get ride of there hot air at any means and get new air in right away it looks like they are just using there air they just push out
Get a wire rack. That wood is holding in heat. spread them out. Get them in direct airflow with the exhaust hot side to the fan. Is the roof of the building black? Maybe make it white to reflect more sunlight?
