Hey guys so im trying to shot for the vest efficiency for my s19j pros i have the 92TH models BB board im on the Braiins OS and on the braiins stratum v2 pool. Can yall share with me your stats for the best efficiency for J per TH i really appreciate it thank you guys
Hey mate, I wrote this a while back about my J pros, however my models are the 126 chip 104T model but the same method will apply about starting on the minimum voltage/freq and working your way up. Dont take note of the Luxos power reader, use a wall reader to read your power consumption. Take your time to read the whole thread
At the moment i have them doing 2300 watts at 85 - 87 TH so around 26 - 27 JTH
Is there any difference from the lux OS and Braiins OS like what are the been a fits if you could elaborate thanks
unfortunately i cant tell you exactly what the best fit for your machine is because ive never used your machine. Really the OS system you use does the same thing - it will change the miner hashboard to function at X voltage and X frequency to achieve X hashrate. The only difference between Lux and braiins is with Lux you can manually set the frequency and voltage, whereas Braiins you set your desired hashrate and it will find what it thinks is the best power consumption for it. But I have found you can push it much further than the auto tuning. In Lux, frequency controls the desired hashrate and voltage controls the power consumption. If you set the hashrate too high for the power consumption then you can wreck your miner. This is why I say in the thread I wrote to start with the minimum voltage and frequency and then slowly up the frequency to make sure you dont damage the boards. This is probably the best way to push your miner to its limit which has more risk, but the safest way would be to use Braiins auto tuning. I think its worth the risk and if you arent silly about it there should be no risk of damaging your boards
