Does anyone know anything about how to do this? What type of fans are these? I would like to swap out the fan for less noise but not lose any hash rate. I see a bunch of modded S9 on ebay that claim to do this.
That does look cool. I have seen some videos on you tube where people put these things in cooler boxes and use that ducking that is typically used for air conditioning to help dampen the noise levels.
Haven’t tested it though, will give it a shot as soon as my new miners arrive.
here is a list of fans that are below 45 decibels but the fastest one only spins at 3000 rpm I need to find out the specs on the airflow of what the L3 comes with though instead of using RPM to guide me
Currently my fans are running at 4920 and 5640 rpms on my antminer. The best silent fan I could find is 3,000 rpms. That’s about 40% less rpms. Does anyone know how this will affect my antminer? Will it overheat?
It didn’t work. With the adapter for 3 to 4 pins, the fans spun but I don’t think its actually compatible. All my shares were rejected. I also got no stats for anything.
