My Mini Doge recently suffered a short in its 6 pin connector port. Gold shell wants me to send the device back to China for a replacement. Does anyone have any other suggestions?
Does yours look similar to this? Iām awaiting parts to repair two of my miners - looks like on some of the models these power connectors are lower quality than on the others and will have to be replaced.
Iāve seen lots of posts around talking about this issue and mainly addressing the PSU problem, but I know this is not the case here. The PSU is good, but these connectors are shittyā¦
Creator, are those soldered to the board or is it plug and go?
They are soldered to the board. I can post more photos once Iāll start repairing / replacing themā¦
Is it worth sending it back to China for a replacement or getting it into a repair shop in the US? They want $260 to ship it
Plus they want you to ship it there. Is it under warranty?? I might be able to submit it for you cheaper through the company. Let me know if you want me to investigate and if itās under warranty!!
I was just about to say the same thing - as far as I know, the official warranty from GS is 180 days. Gets a bit tricky after that. Are you located here in United States? Fingers crossed that RC can maybe help you out with a better deal to get the unit repaired.
Be interesting to see the condition of the soldered joints to the boards in order to ascertain whether poor soldering, cheap and nasty plugs, or even if a combination of both factors were to blame.
Wouldnāt mind seeing the condition of the pcb in the area where the sockets soldered to.
Anyone know where i can order power jacks for GS box miners?
I have 2 that burnt up in the last 6 days. 1st one was on a evga pws, second on a gold shell pws. I think with my 1st one the plug and the jack got cracked from me plugging and unplugging so many times. The box would go down every 3-6 days. The second on the GS pws never went down unless the power went out so maybe 3 times since july/21. The 1st one i was able to clean it up with some contact cleaner, small file, and canned air. The second one Iām thinking i need a new jack.
Wow, thatās scary!! Glad you caught it!!
I ordered mine here:
Still waiting for them to arrive and will post more photos while Iāll be repairing two of my boxes.
Thank you. Got some on order now.
So, I finally was able to repair kd-box and mini-doge miners burnt power connectors. Hereās what soldered joints looked like before I removed the old (burnt) connectors:
Points 1, 2, 3 and 4 did look damaged - hereās couple more views from a different angle:
De-soldering damaged connector was probably the most difficult task, but then a little clean up and adding new connectors was pretty easy.
All good now and power wires as long as the 6-pin plug itself are running warm from being naturally exposed to the exhaust hot air from the miner, but at least not feel as hot as they used to be prior to the repair.
If your still able to access the solder joints itās well worth re-soldering the two remaining joints because the existing ones may have become ādryā and broke down by the heat and current flow. The two remaining look like they could also break down at some point. There doesnāt look like thereās a lot of solder around the pins and the pins look quite thick which can also cause dry joints to form.
MG - this is exactly what I did. I removed the burnt / damaged connector altogether, cleaned all the joints and then installed a brand new 6-pin connector with plenty of fresh solder. May not look pretty, but certainly created a better connection - more solid and generating less heat.
Another update / additional information on this repair.
Besides replacing male power connector (re-soldering it), Iāve also replaced power cables on the PSU (Iām using BITMAIN APW7-12-1800 for my box miners). Below you can see the old cables vs. new ones:
Closer look at the old, burnt ones:
New replacement cables also have much better power connectors:
Nice work!!
Thanks for the link just bought mine.
Just had the same thing with my new Mini Doge. The damage wasnāt that bad, and I replaced the power cord and cleaned the connector post. Itās been running but, I know I should replace the connector.
Do you have a link for these heavier cables? I found many but theyāre all 18AWG and arenāt better than the stock.
