Anyone here try mining off solar power yet?
I haven’t solar mined but I looked into it when you need 1500-2000w just to run one miner that is at least four large panels. That is probably why no one uses it large scale. But if you are just running one s17 lets say It might make sense.
Hi, I am new in mining. Just tried a little GPU mining and now ordered new K5
But I have few years experience on solar panels. First of, you need more equipment than just panels and cables. You need an inverter, mounting brackets etc.
The second thing is that sun doesn’t shine always at least where I live (Finland). I have 3600Wh solar system and right now it starts to produce power about 8.00AM but just a little, after about 11.00AM it’s producing enough to pay my K5
about 1600wh and about 01.00PM it’s producing somewhere between 2000-3000wh till 5.00PM and if it’s cloudy or rainy much less obviously. Solar production will vary very much monthly. During winter time you are not getting that much, obviously depends so much on where you live.
Thirdly, costs. I have paid my system about $6000. But I assume this varies based on where you live etc. However my recommendation is get the knowledge your self, it’s quite simple thing really! Buy your panels, cables, mounting brackets, inverter yourself. Hire yourself electric guy and help him to install them. You can save 50% this is at least in my country.
But my advice is that do not just look at the theoretical watts on panels and calculate the savings. If you are planning to get enough power for like for example, Antminer K5, you’re solar system needs to be much more than 1600Wh. Perhaps 2000-3000wh. And still you can effectively power your mining only for about 6 hours per day from April to September. Outside of those months it drops significantly. And during November to February the solar production is nearly zero (this is where I live)
To save money in mining with solar power might not be as simple as many think. But if you are planning to get solar anyway, prepared to wait 5-10 years before they are really paid, invest your time also on it a lot (significant savings probably), then yes solar makes sense!
Why you don’t try run pmg hydro generator? It will produce 24h power non stop
Good point! I probably would if I’d be living near river etc.
Wind energy is one option also. Not with the traditional ones but types like this one:
You don’t need living close to river
have lots video how to make hydro pmg generator in your basement
i will build one in 1-2 month as required 220v pmg 4000watt, high pressure water pump, water storage for 1000litre and water pump for return water in to tank it will be same principle as you install pmg close to river
also im don couple month ago pump for underground water so in experiments i have free water. My plan is use one or two pmg generators power high pressure water pumps to spin other pmg for power up mining rig. Fallow calculations 1 pmg shut enough run 12x rx580 on 60-70% of power from pmg. In my country i can buy like 10kwh pmg for like 1200usd
cool! Can you link the videos? Sounds interesting
i cant found any more his video as is deleted from youtube. in video it was explain how to make set up in home. it was like his: pmg 220v 4000watt at 4000rpm. him use 1000litre water tank, high pressure water pump set up 2 nozzle at 6bar water pressure and and water pump to return all water bank to tank. 1000litre tank im use for 2x pmg one is power all pumps second pmg send power in to house for lights. any way his setup i can use power up mining rig. i will share experiment setup after i done and power up ring. dont know how long take it as of pandemic everything coming very slow limitation of delivery
you can see lot video in youtube how is work pmg hydro generators
his one cost 150usd plus shipping price fallow voltage and wattage can be order from 150usd 2000-4000watt till 45kwh with one cost around 6000usd, can select on order 12v,24,48v,110v,220v,230v,240v,380v. if you have solar panels so can use fallow your grid voltage to produce power on night, i see couple month ago in one forum dont remember with one some person use 4 his pmg produce power on night and non sun days, him use arduino smart controler to switch power in to grid fallow low voltage it was set up on 48v solar when voltage drop to 24v automatically switch power from solar to pmg to run again 48v
Okay
do you know how much water are these consuming per produced kilowatt?
in video pump was set up 6bar 6.60 mÂł/h to run 4000rpm to get 220v 4000watt 15A
same pump can be use for other voltage pmg no idea how much need power to run like 15kw or 45kw pmg i see 45kw pmg rpm is 250.
any way need to wait till im get all parts and start build, after i can tell more how is work and how much cost and other stuff but in video was good idea how to run pmg in home
https://www.youtube.com/watch?v=kKNYM048eE0 something similar in other video use pelton rotor it was match smaller construction
Your pump will draw more energy than a Pelton wheel connected to a PMG will produce. Motors, pumps, generators and Pelton wheels are not 100% efficient. Unless you have a source of free water that is already pressurized, you will not be getting any free power from a PMG used like this. Your power costs will increase, not decrease.
you not right pelton is spinning vea water pump with one draw only 700watt, pelton produce 4000watt at 240v, 1 pump, 1 pelton = 6x gpu free power. everything is possible if you use your brain. to get free power you can get not only from pelton have and other alternative
how is can my power cost increase if any of my generator are not connected to 220v socked? im not use any pump or other stuff pluging to 220v power sources it is made to run free power, pelton 220v 4000watt connected to 4x battery, pump connected vea inverter 12v to 1000watt inverter and is circulated pelton generate power to use pump and charge batteries to same tame, 2000watt inverter connected to 6x gpu rig. wow it so miracle
for alternative pmg can spin and motor not only water, in 2020 you can buy low power consumption motor with one enough spin pmg and charge your batteries non stop 24/7 more pmg+motor + large capacity storage can power up even your house. some ideas for free power are more of 100year old
A PMG cannot produce more power than it is supplied at the shaft. No generator is perfectly efficient so it will actually produce less power than is input to the shaft. Since you are using a pump that draws 700W, let’s assume the motor efficiency is 95% and the pump efficiency is 80%. You now have a maximum of 532 watts at the nozzle feeding the pelton wheel. Pelton wheels are pretty efficient and so are most generators so let’s call them both 90%. This means you are delivering 479 watts at the shaft and producing 431W out of the generator less any losses from the inverter.
You are trying to go one step beyond perpetual motion. You are going to find that the power draw of the pump will always exceed the power produced by the generator. If a Pelton wheel generator will work, why wouldn’t just connecting the pump motor directly to the generator work even better? It has less efficiency losses but you don’t see that done either. Neither work because of the fact that a PMG cannot produce more power than it is supplied at the shaft.
