yes u can bud
and u coulda asked me also… use Nicehash . pay in btc… mosdt profitable for it anyways @Carl_Canady
wonder which was the dang l3++
Use Hiveon Firmware, 504MH/s @ 660w.
I have 4 L3+ three of them overclocked to 650 mhs each and one clocked at 625. the value chart is based off of stock speed of 500 for one unit. I also am paying around 350 in power per month.
@Master3004 What is the voltage set to on those 2 L3s? I’ve tried to go higher on mine but the temps on 4 of my boards gets close to 80C. Maybe I need to vent my garage better…
What wattage are you running each at?
be careful and set ur fan speed to manual 85+% if on 120v if u know what ur doing, i can do up to 17v if u get good items. id adjusted it over time inc stepping by 1v each and run em atleast 30min DO NOT go over 17. 525… . i dont know ur items. if good qauality u can. !
items can be diffrent … yours wont be the same… u have to adjsut accordingly. one might be able to stay cool at 17v vs the other would have to get dropped to 13… i take no responsibility for ur actions
u can increase ur frequency easily , then check ur HW errors. adjust accordingly with voltage 1 at a time
MUST or RECOMMEND>. SET MANUAL FAN SPEED 85% or more . dont keep it at 100% either
Thanks for that. @Master3004 I’ll keep playing around with them. I would never hold you accountable. Just trying to gather as much info as I can. Right now I have lots of Wyoming winter air to keep them cool. In the summer I’m probably going to have to downclock them a bit.
@Nachlibre I have some boards at 11 some at 10. just depends on if they restart themselves. Ill either clock chips down or bump up the voltage. I am trying to not go over 1000w per box. If I can sqeeze out 20 to 30 more hash for a few watts more and ok temps I will. Anything to accumulate as much as possible.
no reason why ur stuff should be restarting … AT ALL. . and 80 is a bit high … thats when i have mine set to shutdown…
Yeah I think It may have been the Hive On firmware. They aren’t restarting anymore now that I’ve figured out how to flash away from Hive. I totally need some fans as back up. I haven’t bought any yet. How much per fan are you selling them for?
couple buks only cost a doller or 2 from china . and i dont markup like that . get some cover shipping and shiould be good if u want… got cables and think 1 or 2 control boards on person here also maybe 30fans left
2kinds yes i know what they go for here
arent newly taken pics… jsut didnt feel like taking new ones lol
I’ll buy 4 Large fans and 4 small power supply fans if you have them. That should keep me going for quite some time.
actually… i have a few psus fans.and regularslet me ask first … waht RPM and how old are the ones u usehave they \ever been replaced ?
@Master3004 im exploring Vnish on 1 of my L3+ at the moment, looks like the numbers showed in “voltage” are not the actual volts but a preset number, 17= 10.25V. Which makes way more sense…
yes the same with hive i think . i dont like it for those reasons. and a few others… used it 30min and removed it… and i HAVE every FM there is for l3++ and + . even nicehash’s before they killed it. ha ent used it since they did kill it tho
Will do. I need to check on the info on the fans.
ill get u at 5$ ea. which will proly be enough to cover shipping
… its fine… ull notice 20+ temp drop usually . these are 6k+ rpm … JUST DO NOT… keep it constant at 100%
have so many … actually put em in my pc also LOL
Dang man that’s cheap. I can’t find them for less then 15. @Master3004 I found a 706 number on your web page justabitofcoinltd.com Is that you?
dont buy shit there yet
