actually you are not right 231watt runing only whan rig is start mining mot on booting on boot runing around 20-50watt,
about risers on my new rig 12risers are conected on first psu with motherboard second psu power up only 12gpu, other rig 1psu mobo,3x gpu,3x risers second psu 3xriser 3x gpu
second you dont need use molex connectors on mobo is you use power risers molex are only for unpowered risers i do check on my mobo power test from molex power is 0 not using nothing
woohooo my RGB lights started working again! lol
Ghost lights? What did you do?
i was cleaning the dust and taken them apart and put them back together and they started working
check this out ever since i switched back to pool mining thru nicehash my rigs find higher difficulty share and even my smaller rig is out preforming the larger on as far as highest share difficulty solved
Perhaps changing wattman settings with the miner running on the GPU. I’ve had this on my Nvidia cards as well. Restarting the miner works only once in a while … Restarting the computer has worked every time provided (wattman) resets the frequencies to default values
