That is some top-notch tuning.
How the eF? That is pretty insane, even if its a glitch
it was submitting shares too but they were getting marked invalid
Lol, nice. I got something similar when it was running some bench marking. NiceHash came back that I would be making 22 BTC a day estimated
I didnāt grab screenshot of it though, unfortunately.
@dealerraw There is no Free Money in the World my child⦠GROW UP!
Donāt fall for any pyramid and crypto scams
And you have money, you have the internet and device to visit voskcointalk
DO NOT BUY THESE FANS THEY STILL WORK BUT THE RGB LIGHTS DO NOT WORK ANYMORE
That sucks. Iām finding a lot of crappy suppliers these days. never used to have to worry about stuff like this in the old days, but now I cant even get Best Buy hdd to last more than a week. sorry dude
I do the sameā¦monero with my cpu while Ravencoin with my gpuā¦no issues so far⦠May get a new cpu/mb with more room for gpuās so may go with a ryzen and get after it
about to be done with HiveOS things havenāt been working as smoothly lately and they been having to put out a new update almost everyday to repair all of the bugs and now they want to start charging me no matter how many rigs you have.
then I had this happen I wake up and it looks like all of my overclock settings are being ignored on two GPUās one is not running at the fan speed set and they both are using 40 watts more than they should be
what i told you hiveos is shit for me enought problem witch asic miners on hive never ever in my life hive
I sold a couple of my RX 470ās to buy another 5700 but I am having so much trouble getting more than 6 GPUās to work on this ASUS B25o mining MOBO. Anyone have any experience with this? I have put it together and taken it apart a few times making sure I have the PSUās properly separated and wired into the correct spots I can not even get the rig to boot at all to get into BIOS
MeatyMouse - Iām using this board and currently running it with 6 x RX5700s and 3 x RX570s. I have another 3 x RX570s Iām going to put on it when I get a bigger PSU.
I have a 1200w PSU and it struggled to manage the initial power requirements for the 6 x 5700s. I could usually get it going but it would struggle under load. As soon as I added another PSU and more cards, I had the same as you - nothing and couldnāt even get to the BIOS.
When I added the other 1200w PSU to the āBā slots, I tried all sorts of sharing of the motherboard power requirements in order to get 6 GPUās running again in the āAā slots and the āBā slots For a while I was successfully running 5 RX5700s in the A Slots and 6 RX570s in the B slots but it didnāt remain stable for long. Right now, I have the āAā PSU running all the motherboard power requirements (24pin ATX, 8pin CPU, 3 x 4pin Molex to the PCIEs and the SSD) and then I can get it to run 4 x RX5700s supplying power to the cards and the risers. I have the other 1200w PSU running the remaining 2 x RX5700 as well as 3 of my RX570s in the B slots. I think I could get another RX570 running on the B slots but Iām leaving it for now. Itās pretty stable (considering itās on Windows) and giving me about 405MH/s in Phoenixminer.
I donāt know what sort of PSU you have but my guess would be power is your problem (given that it runs okay with 6 GPUs in the A slots???).
Iām waiting on delivery of a 1600w PSU and hoping that I will then be able to take this up to an 18 GPU rig - I have 6 more RX570s chugging away on a H110 BTC+ rig.
lol no way I am running a 1300w and a 1200w both EVGA the 1300 is gold and the 1200 platinum
I will try that config you mentioned though
MeatyMouse. Iām not so sure. The max power draw on an RX5700 is 231w although generally they will peak out in the lower 200s. This can often occur during power on so if you are trying to flash up 6 x RX5700s, their risers, the motherboard, the CPU, the fans and a hard drive, itās not inconceivable that you will quickly exceed your 1300w capacity.
See how you go with different combos.
I only have 5 5700ās and 4 470ās I do have 6 GPUās and the risers for them on the same PSU I will try to mover the riser power to the second PSU instead
I donāt think that will work - well it didnāt for me. I think you have to make a circuit out of each GPU/Riser combination. In other words, the GPU and its Riser need to be on the same PSU. See if it works for you.
What I wasnāt clear on was that I had 6 x 5700s running on one PSU in the A slots, but as soon as I tried to run more GPUs in the B slots, I couldnāt get the rig to work - even 1 GPU in the B slot wouldnāt boot. It was like there was additional power requirements for the Main PSU as soon as I started using the B slots.
this totally makes sense because I even tried to only run one PSU with 9 GPUās and the rig acted exactly the same as having all 9 cards on I think having 5 on one PSU and 4 on the other should work much better hopefully getting tired of rebuilding this damn rig lol
